It is currently Fri Aug 22, 2025 7:56 am
PostPosted: Sun Dec 01, 2013 10:35 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
Maybe everyone else has discovered this but it was a eureka moment for me. I'm still on the steep part of the learning curve here.
I was getting ready to glue an x-brace to a top, practicing the move because of the short open time of HHG. I was struggling with getting the x-brace in proper position on first attempt. Then I realized I could use some go-bar rods as stops to guide the placement of the x-brace. I placed 5 rods so the x-brace was perfectly aligned when pressed up against them.
It was easy to quickly apply the HHG and drop the x-brace in proper position. I was even able to quickly use those 5 rods as my first clamps.
It went without a hitch! Hope this helps someone else.
PostPosted: Sun Dec 01, 2013 11:32 pm
You can also use small L-shaped stop blocks under the gobars, with the end of the brace inside the L to locate in two axes, plus avoid making dents in your top.
PostPosted: Mon Dec 02, 2013 6:56 pm
I think I'll give it a try....
PostPosted: Mon Dec 02, 2013 7:24 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I like Todd's suggestion also...gonna give it a try :-)
Gene
PostPosted: Tue Dec 03, 2013 2:39 am
First name: Hilko
Last Name: Nackaerts
Country: Belgium
Todd many thanks! I'll be trying this next week!
FB Page
PostPosted: Tue Dec 03, 2013 6:47 pm
Another thing that I do is to have several go bars pre-positioned just out north of the path of the upper part of the X brace, then after positioning against go bar stops, simply reposition the others onto the X brace. I can also get a few of the lower go bars pre positioned too. Just do a dry run to make sure you have left room to place the X. Saves time when using HHG.
Chuck
PostPosted: Wed Dec 04, 2013 6:33 pm
I use this halo pattern ,. it locks me in and I can use it to mark the top to notch the lining.
